Time Before: 0.00147 seconds
Time After: 0.00201 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00208 seconds
Time After: 0.00262 seconds
Time Before: 0.00286 seconds
Time After: 0.00307 seconds
Time Before: 0.00371 seconds
Time After: 0.00695 seconds
Time Taken: 0.00324 seconds
Time Before: 0.00313 seconds
Time After: 0.01079 seconds
Time Taken: 0.00766 seconds
Time Before: 0.01286 seconds
Time After: 0.01326 seconds
Time Before: 0.01573 seconds
Time After: 0.01696 seconds
Time Before: 0.01220 seconds
Time After: 0.01716 seconds
Time Taken: 0.00496 seconds
Time Before: 0.02208 seconds
Time After: 0.02228 seconds
Time Before: 0.02428 seconds
Time After: 0.02557 seconds
End call of global.php: 0.027158975601196
Time Before: 0.02902 seconds
Time After: 0.02921 seconds
Time Before: 0.03124 seconds
Time After: 0.03350 seconds
Time Taken: 0.00226 seconds
SET lastactivity = 1788970499, location = '/forums/private.php?do=newpm&explain=1&u=126670', badlocation = 1
Time Before: 0.04615 seconds
Time After: 0.04650 seconds
Page generated in 0.045257091522217 seconds with 9 queries, spending 0.00990891456604 doing MySQL queries and 0.035348176956177 doing PHP things.
