Time Before: 0.00185 seconds
Time After: 0.00241 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00249 seconds
Time After: 0.00306 seconds
Time Before: 0.00326 seconds
Time After: 0.00340 seconds
Time Before: 0.00407 seconds
Time After: 0.00689 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00346 seconds
Time After: 0.01023 seconds
Time Taken: 0.00677 seconds
Time Before: 0.01203 seconds
Time After: 0.01220 seconds
Time Before: 0.01364 seconds
Time After: 0.01491 seconds
Time Before: 0.01145 seconds
Time After: 0.01509 seconds
Time Taken: 0.00364 seconds
Time Before: 0.02138 seconds
Time After: 0.02153 seconds
Time Before: 0.97710 seconds
Time After: 0.97883 seconds
Time Taken: 0.00172 seconds
Time Before: 0.98176 seconds
Time After: 0.98191 seconds
Time Before: 0.98392 seconds
Time After: 0.98537 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=126678', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.99774 seconds
Time After: 0.99799 seconds
