Time Before: 0.03814 seconds
Time After: 0.05116 seconds
Time Taken: 0.01302 seconds
Time Before: 0.05124 seconds
Time After: 0.05174 seconds
Time Before: 0.05203 seconds
Time After: 0.05216 seconds
Time Before: 0.05294 seconds
Time After: 0.05549 seconds
Time Taken: 0.00255 seconds
Time Before: 0.05222 seconds
Time After: 0.05949 seconds
Time Taken: 0.00727 seconds
Time Before: 0.07458 seconds
Time After: 0.07480 seconds
Time Before: 0.07776 seconds
Time After: 0.07896 seconds
Time Before: 0.07395 seconds
Time After: 0.07916 seconds
Time Taken: 0.00521 seconds
Time Before: 0.13240 seconds
Time After: 0.13258 seconds
Time Before: 0.15843 seconds
Time After: 0.15970 seconds
Time Before: 0.17516 seconds
Time After: 0.17533 seconds
Time Before: 0.17767 seconds
Time After: 0.17912 seconds
UPDATE session SET lastactivity = 1783199397, location = '/forums/private.php?do=newpm&explain=1&u=126732' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.20042 seconds
Time After: 0.20074 seconds
