Time Before: 0.02110 seconds
Time After: 0.02840 seconds
Time Taken: 0.00730 seconds
Time Before: 0.02850 seconds
Time After: 0.02903 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02932 seconds
Time After: 0.02948 seconds
Time Before: 0.03035 seconds
Time After: 0.03288 seconds
Time Taken: 0.00253 seconds
Time Before: 0.02957 seconds
Time After: 0.03688 seconds
Time Before: 0.04434 seconds
Time After: 0.04476 seconds
Time Before: 0.04722 seconds
Time After: 0.04852 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04367 seconds
Time After: 0.04869 seconds
Time Taken: 0.00502 seconds
Memory After: 2,261.820 KB
Time Before: 0.08781 seconds
Time After: 0.08797 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10669 seconds
Time After: 0.10797 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.11672 seconds
Time After: 0.11689 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11929 seconds
Time After: 0.12074 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788901325, location = '/forums/private.php?do=newpm&explain=1&u=126766' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14091 seconds
Time After: 0.14119 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
