Time Before: 0.00853 seconds
Time After: 0.01148 seconds
Time Taken: 0.00295 seconds
Time Before: 0.01157 seconds
Time After: 0.01203 seconds
Time Before: 0.01225 seconds
Time After: 0.01238 seconds
Time Before: 0.01313 seconds
Time After: 0.01778 seconds
Time Taken: 0.00466 seconds
Time Before: 0.01245 seconds
Time After: 0.02197 seconds
Time Taken: 0.00953 seconds
Time Before: 0.02603 seconds
Time After: 0.02645 seconds
Time Before: 0.02852 seconds
Time After: 0.02975 seconds
Time Before: 0.02532 seconds
Time After: 0.02998 seconds
Time Before: 0.04833 seconds
Time After: 0.04848 seconds
Time Before: 0.05637 seconds
Time After: 0.05843 seconds
Time Taken: 0.00206 seconds
End call of global.php: 0.06072998046875
Time Before: 0.06408 seconds
Time After: 0.06422 seconds
Time Before: 0.06656 seconds
Time After: 0.06804 seconds
SET lastactivity = 1789115458, location = '/forums/private.php?do=newpm&explain=1&u=126800'
Time Before: 0.08234 seconds
Time After: 0.08288 seconds
Time Taken: 0.00054 seconds
Page generated in 0.081434011459351 seconds with 9 queries, spending 0.011268854141235 doing MySQL queries and 0.070165157318115 doing PHP things.
