Time Before: 0.00182 seconds
Time After: 0.00247 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00258 seconds
Time After: 0.00310 seconds
Time Before: 0.00342 seconds
Time After: 0.00357 seconds
Time Before: 0.00439 seconds
Time After: 0.00696 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00363 seconds
Time After: 0.01043 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01326 seconds
Time After: 0.01372 seconds
Time Before: 0.01732 seconds
Time After: 0.01941 seconds
Time Taken: 0.00209 seconds
Time Before: 0.01250 seconds
Time After: 0.01963 seconds
Time Taken: 0.00713 seconds
Time Before: 0.02766 seconds
Time After: 0.02780 seconds
Time Before: 0.03152 seconds
Time After: 0.03285 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03762 seconds
Time After: 0.03779 seconds
Time Before: 0.04110 seconds
Time After: 0.04255 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=126849' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05723 seconds
Time After: 0.05759 seconds
