Time Before: 0.00206 seconds
Time After: 0.00279 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00289 seconds
Time After: 0.00341 seconds
Time Before: 0.00362 seconds
Time After: 0.00377 seconds
Time Before: 0.00446 seconds
Time After: 0.00728 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00382 seconds
Time After: 0.01174 seconds
Time Taken: 0.00792 seconds
Time Before: 0.01398 seconds
Time After: 0.01440 seconds
Time Before: 0.01587 seconds
Time After: 0.01735 seconds
Time Before: 0.01331 seconds
Time After: 0.01753 seconds
Time Taken: 0.00422 seconds
Time Before: 0.02271 seconds
Time After: 0.02283 seconds
Time Before: 0.02486 seconds
Time After: 0.02612 seconds
Time Before: 0.02888 seconds
Time After: 0.02907 seconds
Time Before: 0.03107 seconds
Time After: 0.03255 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=126861' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04491 seconds
Time After: 0.04522 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
