Time Before: 0.00155 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00253 seconds
Time Before: 0.00274 seconds
Time After: 0.00290 seconds
Time Before: 0.00357 seconds
Time After: 0.00627 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00294 seconds
Time After: 0.00965 seconds
Time Taken: 0.00671 seconds
Time Before: 0.01197 seconds
Time After: 0.01240 seconds
Time Before: 0.01495 seconds
Time After: 0.01622 seconds
Time Before: 0.01129 seconds
Time After: 0.01640 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02143 seconds
Time After: 0.02167 seconds
Time Before: 0.02345 seconds
Time After: 0.02472 seconds
End call of global.php: 0.026348114013672
Time Before: 0.02762 seconds
Time After: 0.02786 seconds
Time Before: 0.02988 seconds
Time After: 0.03133 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=126896', badlocation = 1
Time Before: 0.04403 seconds
Time After: 0.04426 seconds
Page generated in 0.042880058288574 seconds with 9 queries, spending 0.0083811283111572 doing MySQL queries and 0.034498929977417 doing PHP things.
