Time Before: 0.00195 seconds
Time After: 0.00280 seconds
Time Taken: 0.00086 seconds
Time Before: 0.00288 seconds
Time After: 0.00352 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00375 seconds
Time After: 0.00389 seconds
Time Before: 0.00454 seconds
Time After: 0.00700 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00394 seconds
Time After: 0.01046 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01230 seconds
Time After: 0.01257 seconds
Time Before: 0.01513 seconds
Time After: 0.01640 seconds
Time Before: 0.01164 seconds
Time After: 0.01659 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02193 seconds
Time After: 0.02215 seconds
Time Before: 0.02429 seconds
Time After: 0.02559 seconds
End call of global.php: 0.027251958847046
Time Before: 0.02880 seconds
Time After: 0.02897 seconds
Time Before: 0.03175 seconds
Time After: 0.03323 seconds
SET lastactivity = 1783094358, location = '/forums/private.php?do=newpm&explain=1&u=126907'
Time Before: 0.04558 seconds
Time After: 0.04588 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.044666051864624 seconds with 9 queries, spending 0.0082590579986572 doing MySQL queries and 0.036406993865967 doing PHP things.
