Time Before: 0.00256 seconds
Time After: 0.00314 seconds
Time Taken: 0.00057 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00323 seconds
Time After: 0.00384 seconds
Time Taken: 0.00061 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00409 seconds
Time After: 0.00420 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00499 seconds
Time After: 0.00764 seconds
Time Taken: 0.00265 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00425 seconds
Time After: 0.01244 seconds
Time Taken: 0.00819 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01429 seconds
Time After: 0.01463 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01710 seconds
Time After: 0.01831 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01370 seconds
Time After: 0.01851 seconds
Time Taken: 0.00481 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02464 seconds
Time After: 0.02476 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03217 seconds
Time After: 0.03338 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.04348 seconds
Time After: 0.04367 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04603 seconds
Time After: 0.04748 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=126962' WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.06168 seconds
Time After: 0.06202 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
