Time Before: 0.00140 seconds
Time After: 0.00196 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00203 seconds
Time After: 0.00239 seconds
Time Before: 0.00258 seconds
Time After: 0.00269 seconds
Time Before: 0.00355 seconds
Time After: 0.00625 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00274 seconds
Time After: 0.01077 seconds
Time Taken: 0.00803 seconds
Time Before: 0.01260 seconds
Time After: 0.01304 seconds
Time Before: 0.01567 seconds
Time After: 0.01695 seconds
Time Before: 0.01199 seconds
Time After: 0.01720 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02411 seconds
Time After: 0.02432 seconds
Time Before: 0.02651 seconds
Time After: 0.02780 seconds
End call of global.php: 0.029779195785522
Time Before: 0.03093 seconds
Time After: 0.03115 seconds
Time Before: 0.03326 seconds
Time After: 0.03470 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=127006'
Time Before: 0.04740 seconds
Time After: 0.04765 seconds
Page generated in 0.046485185623169 seconds with 9 queries, spending 0.0082781314849854 doing MySQL queries and 0.038207054138184 doing PHP things.
