Time Before: 0.02324 seconds
Time After: 0.02998 seconds
Time Taken: 0.00674 seconds
Time Before: 0.03009 seconds
Time After: 0.03048 seconds
Time Before: 0.03070 seconds
Time After: 0.03084 seconds
Time Before: 0.03165 seconds
Time After: 0.03450 seconds
Time Taken: 0.00285 seconds
Time Before: 0.03090 seconds
Time After: 0.03896 seconds
Time Taken: 0.00805 seconds
Time Before: 0.04852 seconds
Time After: 0.04890 seconds
Time Before: 0.05140 seconds
Time After: 0.05264 seconds
Time Before: 0.04779 seconds
Time After: 0.05289 seconds
Time Taken: 0.00510 seconds
Time Before: 0.09005 seconds
Time After: 0.09022 seconds
Time Before: 0.10896 seconds
Time After: 0.11022 seconds
Time Before: 0.12277 seconds
Time After: 0.12298 seconds
Time Before: 0.12604 seconds
Time After: 0.12759 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127042', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.15007 seconds
Time After: 0.15034 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
