Time Before: 0.00618 seconds
Time After: 0.00868 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00877 seconds
Time After: 0.00918 seconds
Time Before: 0.00952 seconds
Time After: 0.00969 seconds
Time Before: 0.01056 seconds
Time After: 0.01278 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00976 seconds
Time After: 0.01703 seconds
Time Taken: 0.00727 seconds
Time Before: 0.02160 seconds
Time After: 0.02205 seconds
Time Before: 0.02484 seconds
Time After: 0.02708 seconds
Time Taken: 0.00224 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02073 seconds
Time After: 0.02737 seconds
Time Taken: 0.00664 seconds
Memory After: 2,261.836 KB
Time Before: 0.04221 seconds
Time After: 0.04237 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05007 seconds
Time After: 0.05138 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.053682804107666
Time Before: 0.05691 seconds
Time After: 0.05706 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.05951 seconds
Time After: 0.06099 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789137030, location = '/forums/private.php?do=newpm&explain=1&u=12708'
Time Before: 0.07905 seconds
Time After: 0.07933 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.077860832214355 seconds with 9 queries, spending 0.0088605880737305 doing MySQL queries and 0.069000244140625 doing PHP things.
