Time Before: 0.00166 seconds
Time After: 0.00225 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00234 seconds
Time After: 0.00278 seconds
Time Before: 0.00306 seconds
Time After: 0.00323 seconds
Time Before: 0.00401 seconds
Time After: 0.00646 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00332 seconds
Time After: 0.00981 seconds
Time Taken: 0.00649 seconds
Time Before: 0.01165 seconds
Time After: 0.01209 seconds
Time Before: 0.01453 seconds
Time After: 0.01572 seconds
Time Before: 0.01109 seconds
Time After: 0.01596 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02139 seconds
Time After: 0.02156 seconds
Time Before: 0.02408 seconds
Time After: 0.02534 seconds
Time Before: 0.02840 seconds
Time After: 0.02857 seconds
Time Before: 0.03142 seconds
Time After: 0.03292 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1788946119, location = '/forums/private.php?do=newpm&explain=1&u=127080' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05343 seconds
Time After: 0.05378 seconds
