Time Before: 0.00792 seconds
Time After: 0.00974 seconds
Time Taken: 0.00183 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00982 seconds
Time After: 0.01035 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01065 seconds
Time After: 0.01084 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01155 seconds
Time After: 0.01376 seconds
Time Taken: 0.00221 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01090 seconds
Time After: 0.01721 seconds
Time Taken: 0.00630 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01924 seconds
Time After: 0.01966 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02197 seconds
Time After: 0.02320 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01860 seconds
Time After: 0.02338 seconds
Time Taken: 0.00478 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.03994 seconds
Time After: 0.04013 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.05616 seconds
Time After: 0.05749 seconds
Time Taken: 0.00134 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.06947 seconds
Time After: 0.06965 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.07234 seconds
Time After: 0.07388 seconds
Time Taken: 0.00154 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127108' WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.09585 seconds
Time After: 0.09621 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
