Time Before: 0.00154 seconds
Time After: 0.00204 seconds
Time Before: 0.00212 seconds
Time After: 0.00260 seconds
Time Before: 0.00291 seconds
Time After: 0.00309 seconds
Time Before: 0.00382 seconds
Time After: 0.00645 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00313 seconds
Time After: 0.00980 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01162 seconds
Time After: 0.01203 seconds
Time Before: 0.01462 seconds
Time After: 0.01599 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01096 seconds
Time After: 0.01616 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02136 seconds
Time After: 0.02159 seconds
Time Before: 0.02365 seconds
Time After: 0.02494 seconds
End call of global.php: 0.027769088745117
Time Before: 0.02908 seconds
Time After: 0.02930 seconds
Time Before: 0.03154 seconds
Time After: 0.03300 seconds
SET lastactivity = 1782998264, location = '/forums/private.php?do=newpm&explain=1&u=127122'
Time Before: 0.04578 seconds
Time After: 0.04606 seconds
Page generated in 0.044891119003296 seconds with 9 queries, spending 0.0085444450378418 doing MySQL queries and 0.036346673965454 doing PHP things.
