Time Before: 0.01156 seconds
Time After: 0.01575 seconds
Time Taken: 0.00418 seconds
Time Before: 0.01586 seconds
Time After: 0.01640 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01671 seconds
Time After: 0.01684 seconds
Time Before: 0.01774 seconds
Time After: 0.02015 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01692 seconds
Time After: 0.02484 seconds
Time Taken: 0.00792 seconds
Time Before: 0.03146 seconds
Time After: 0.03186 seconds
Time Before: 0.03420 seconds
Time After: 0.03545 seconds
Time Before: 0.03074 seconds
Time After: 0.03570 seconds
Time Taken: 0.00496 seconds
Time Before: 0.06004 seconds
Time After: 0.06019 seconds
Time Before: 0.06879 seconds
Time After: 0.07010 seconds
Time Taken: 0.00131 seconds
Time Before: 0.07622 seconds
Time After: 0.07642 seconds
Time Before: 0.07872 seconds
Time After: 0.08015 seconds
UPDATE session SET lastactivity = 1769166094, location = '/forums/private.php?do=newpm&explain=1&u=127153' WHERE sessionhash = 'cf9a7d249f143a0ae3eb7b561aa7a27f'
Time Before: 0.09638 seconds
Time After: 0.09669 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
