Time Before: 0.00144 seconds
Time After: 0.00202 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00209 seconds
Time After: 0.00269 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00291 seconds
Time After: 0.00304 seconds
Time Before: 0.00385 seconds
Time After: 0.00655 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00312 seconds
Time After: 0.01189 seconds
Time Taken: 0.00876 seconds
Time Before: 0.01407 seconds
Time After: 0.01455 seconds
Time Before: 0.01592 seconds
Time After: 0.01714 seconds
Time Before: 0.01335 seconds
Time After: 0.01733 seconds
Time Taken: 0.00398 seconds
Time Before: 0.02245 seconds
Time After: 0.02260 seconds
Time Before: 0.02448 seconds
Time After: 0.02575 seconds
Time Before: 0.02955 seconds
Time After: 0.02973 seconds
Time Before: 0.03204 seconds
Time After: 0.03368 seconds
Time Taken: 0.00164 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127155' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04869 seconds
Time After: 0.04929 seconds
