Time Before: 0.02433 seconds
Time After: 0.03163 seconds
Time Taken: 0.00730 seconds
Time Before: 0.03171 seconds
Time After: 0.03213 seconds
Time Before: 0.03252 seconds
Time After: 0.03264 seconds
Time Before: 0.03336 seconds
Time After: 0.03580 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03271 seconds
Time After: 0.04042 seconds
Time Taken: 0.00771 seconds
Time Before: 0.04679 seconds
Time After: 0.04696 seconds
Time Before: 0.04836 seconds
Time After: 0.04957 seconds
Time Before: 0.04612 seconds
Time After: 0.04982 seconds
Time Taken: 0.00370 seconds
Time Before: 0.07892 seconds
Time After: 0.07906 seconds
Time Before: 0.08991 seconds
Time After: 0.09117 seconds
Time Before: 0.09935 seconds
Time After: 0.09949 seconds
Time Before: 0.10197 seconds
Time After: 0.10349 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127167', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.12109 seconds
Time After: 0.12137 seconds
