Time Before: 0.00200 seconds
Time After: 0.00261 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00272 seconds
Time After: 0.00346 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00392 seconds
Time After: 0.00426 seconds
Time Before: 0.00513 seconds
Time After: 0.00859 seconds
Time Taken: 0.00347 seconds
Time Before: 0.00434 seconds
Time After: 0.01211 seconds
Time Taken: 0.00777 seconds
Time Before: 0.01409 seconds
Time After: 0.01428 seconds
Time Before: 0.01754 seconds
Time After: 0.01938 seconds
Time Taken: 0.00184 seconds
Time Before: 0.01345 seconds
Time After: 0.01956 seconds
Time Taken: 0.00611 seconds
Time Before: 0.02651 seconds
Time After: 0.02667 seconds
Time Before: 0.02857 seconds
Time After: 0.02985 seconds
End call of global.php: 0.031628131866455
Time Before: 0.03307 seconds
Time After: 0.03325 seconds
Time Before: 0.03589 seconds
Time After: 0.03799 seconds
Time Taken: 0.00211 seconds
SET lastactivity = 1776872482, location = '/forums/private.php?do=newpm&explain=1&u=127178', badlocation = 1
Time Before: 0.05185 seconds
Time After: 0.05213 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.050899982452393 seconds with 9 queries, spending 0.010583162307739 doing MySQL queries and 0.040316820144653 doing PHP things.
