Time Before: 0.00170 seconds
Time After: 0.00251 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00258 seconds
Time After: 0.00303 seconds
Time Before: 0.00323 seconds
Time After: 0.00336 seconds
Time Before: 0.00400 seconds
Time After: 0.00705 seconds
Time Taken: 0.00305 seconds
Time Before: 0.00340 seconds
Time After: 0.01171 seconds
Time Taken: 0.00831 seconds
Time Before: 0.01377 seconds
Time After: 0.01424 seconds
Time Before: 0.01657 seconds
Time After: 0.01802 seconds
Time Before: 0.01321 seconds
Time After: 0.01819 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02320 seconds
Time After: 0.02343 seconds
Time Before: 0.02525 seconds
Time After: 0.02728 seconds
Time Taken: 0.00203 seconds
End call of global.php: 0.028939962387085
Time Before: 0.03024 seconds
Time After: 0.03043 seconds
Time Before: 0.03248 seconds
Time After: 0.03392 seconds
SET lastactivity = 1789082581, location = '/forums/private.php?do=newpm&explain=1&u=127181', badlocation = 1
Time Before: 0.04675 seconds
Time After: 0.04705 seconds
Page generated in 0.045717000961304 seconds with 9 queries, spending 0.0097322463989258 doing MySQL queries and 0.035984754562378 doing PHP things.
