Time Before: 0.02332 seconds
Time After: 0.02956 seconds
Time Taken: 0.00624 seconds
Time Before: 0.02964 seconds
Time After: 0.03005 seconds
Time Before: 0.03025 seconds
Time After: 0.03038 seconds
Time Before: 0.03118 seconds
Time After: 0.03362 seconds
Time Taken: 0.00244 seconds
Time Before: 0.03045 seconds
Time After: 0.03799 seconds
Time Taken: 0.00754 seconds
Time Before: 0.04632 seconds
Time After: 0.04655 seconds
Time Before: 0.04911 seconds
Time After: 0.05028 seconds
Time Taken: 0.00116 seconds
Time Before: 0.04570 seconds
Time After: 0.05050 seconds
Time Taken: 0.00479 seconds
Time Before: 0.09507 seconds
Time After: 0.09521 seconds
Time Before: 0.12172 seconds
Time After: 0.12299 seconds
Time Before: 0.13305 seconds
Time After: 0.13320 seconds
Time Before: 0.13586 seconds
Time After: 0.13729 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127200' WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.15719 seconds
Time After: 0.15752 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
