Time Before: 0.01927 seconds
Time After: 0.02614 seconds
Time Taken: 0.00687 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02624 seconds
Time After: 0.02667 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02697 seconds
Time After: 0.02763 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02848 seconds
Time After: 0.03058 seconds
Time Taken: 0.00210 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02769 seconds
Time After: 0.03456 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04181 seconds
Time After: 0.04221 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04351 seconds
Time After: 0.04473 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04112 seconds
Time After: 0.04497 seconds
Time Taken: 0.00385 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08108 seconds
Time After: 0.08121 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.12432 seconds
Time After: 0.12560 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.14532 seconds
Time After: 0.14550 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.14999 seconds
Time After: 0.15146 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773095922, location = '/forums/private.php?do=newpm&explain=1&u=127220' WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.17381 seconds
Time After: 0.17413 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
