Time Before: 0.02701 seconds
Time After: 0.03350 seconds
Time Taken: 0.00650 seconds
Time Before: 0.03365 seconds
Time After: 0.03538 seconds
Time Taken: 0.00172 seconds
Time Before: 0.03560 seconds
Time After: 0.03578 seconds
Time Before: 0.03685 seconds
Time After: 0.03964 seconds
Time Taken: 0.00279 seconds
Time Before: 0.03586 seconds
Time After: 0.04366 seconds
Time Taken: 0.00780 seconds
Time Before: 0.05310 seconds
Time After: 0.05348 seconds
Time Before: 0.05539 seconds
Time After: 0.05657 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05244 seconds
Time After: 0.05679 seconds
Time Taken: 0.00435 seconds
Memory After: 2,261.820 KB
Time Before: 0.10212 seconds
Time After: 0.10226 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 2.94421 seconds
Time After: 2.94626 seconds
Time Taken: 0.00205 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 2.95874 seconds
Time After: 2.95892 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 2.96146 seconds
Time After: 2.96318 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788976045, location = '/forums/private.php?do=newpm&explain=1&u=127241', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 2.98211 seconds
Time After: 2.98232 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
