Time Before: 0.00136 seconds
Time After: 0.00179 seconds
Time Before: 0.00187 seconds
Time After: 0.00332 seconds
Time Before: 0.00356 seconds
Time After: 0.00370 seconds
Time Before: 0.00435 seconds
Time After: 0.00647 seconds
Time Taken: 0.00211 seconds
Time Before: 0.00375 seconds
Time After: 0.01208 seconds
Time Taken: 0.00834 seconds
Time Before: 0.01451 seconds
Time After: 0.01487 seconds
Time Before: 0.01627 seconds
Time After: 0.01759 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01383 seconds
Time After: 0.01777 seconds
Time Taken: 0.00394 seconds
Time Before: 0.02306 seconds
Time After: 0.02327 seconds
Time Before: 0.02596 seconds
Time After: 0.02728 seconds
Time Before: 0.03163 seconds
Time After: 0.03188 seconds
Time Before: 0.03428 seconds
Time After: 0.03572 seconds
UPDATE session SET lastactivity = 1785298119, location = '/forums/private.php?do=newpm&explain=1&u=127248' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04805 seconds
Time After: 0.04833 seconds
