Time Before: 0.02567 seconds
Time After: 0.03104 seconds
Time Taken: 0.00537 seconds
Time Before: 0.03116 seconds
Time After: 0.03160 seconds
Time Before: 0.03184 seconds
Time After: 0.03197 seconds
Time Before: 0.03272 seconds
Time After: 0.03501 seconds
Time Taken: 0.00228 seconds
Time Before: 0.03204 seconds
Time After: 0.03921 seconds
Time Taken: 0.00717 seconds
Time Before: 0.04638 seconds
Time After: 0.04662 seconds
Time Before: 0.04925 seconds
Time After: 0.05045 seconds
Time Before: 0.04565 seconds
Time After: 0.05068 seconds
Time Taken: 0.00503 seconds
Time Before: 0.09886 seconds
Time After: 0.09901 seconds
Time Before: 0.18533 seconds
Time After: 0.18655 seconds
Time Before: 0.19600 seconds
Time After: 0.19616 seconds
Time Before: 0.19873 seconds
Time After: 0.20110 seconds
Time Taken: 0.00237 seconds
UPDATE session SET lastactivity = 1783079617, location = '/forums/private.php?do=newpm&explain=1&u=12726', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.21873 seconds
Time After: 0.21897 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
