Time Before: 0.01552 seconds
Time After: 0.01941 seconds
Time Taken: 0.00389 seconds
Time Before: 0.01948 seconds
Time After: 0.01991 seconds
Time Before: 0.02017 seconds
Time After: 0.02031 seconds
Time Before: 0.02102 seconds
Time After: 0.02357 seconds
Time Taken: 0.00255 seconds
Time Before: 0.02036 seconds
Time After: 0.02735 seconds
Time Taken: 0.00699 seconds
Time Before: 0.03193 seconds
Time After: 0.03233 seconds
Time Before: 0.03377 seconds
Time After: 0.03503 seconds
Time Before: 0.03128 seconds
Time After: 0.03534 seconds
Time Taken: 0.00406 seconds
Time Before: 0.05940 seconds
Time After: 0.05955 seconds
Time Before: 0.07330 seconds
Time After: 0.07460 seconds
Time Before: 0.08582 seconds
Time After: 0.08600 seconds
Time Before: 0.08853 seconds
Time After: 0.08997 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=12727' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.10890 seconds
Time After: 0.10918 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
