Time Before: 0.00161 seconds
Time After: 0.00217 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00225 seconds
Time After: 0.00264 seconds
Time Before: 0.00322 seconds
Time After: 0.00336 seconds
Time Before: 0.00457 seconds
Time After: 0.00870 seconds
Time Taken: 0.00413 seconds
Time Before: 0.00344 seconds
Time After: 0.01215 seconds
Time Taken: 0.00871 seconds
Time Before: 0.01443 seconds
Time After: 0.01499 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01760 seconds
Time After: 0.01897 seconds
Time Taken: 0.00138 seconds
Time Before: 0.01364 seconds
Time After: 0.01915 seconds
Time Taken: 0.00551 seconds
Time Before: 0.02453 seconds
Time After: 0.02467 seconds
Time Before: 0.02754 seconds
Time After: 0.02924 seconds
Time Taken: 0.00170 seconds
End call of global.php: 0.031044960021973
Time Before: 0.03262 seconds
Time After: 0.03276 seconds
Time Before: 0.03519 seconds
Time After: 0.03662 seconds
SET lastactivity = 1788887575, location = '/forums/private.php?do=newpm&explain=1&u=127347'
Time Before: 0.05061 seconds
Time After: 0.05118 seconds
Page generated in 0.049699068069458 seconds with 9 queries, spending 0.010579109191895 doing MySQL queries and 0.039119958877563 doing PHP things.
