Time Before: 0.00497 seconds
Time After: 0.00695 seconds
Time Taken: 0.00198 seconds
Time Before: 0.00705 seconds
Time After: 0.00773 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00799 seconds
Time After: 0.00815 seconds
Time Before: 0.00885 seconds
Time After: 0.01088 seconds
Time Taken: 0.00202 seconds
Time Before: 0.00820 seconds
Time After: 0.01427 seconds
Time Taken: 0.00607 seconds
Time Before: 0.01697 seconds
Time After: 0.01747 seconds
Time Before: 0.02019 seconds
Time After: 0.02137 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01630 seconds
Time After: 0.02154 seconds
Time Taken: 0.00524 seconds
Time Before: 0.03096 seconds
Time After: 0.03113 seconds
Time Before: 0.03584 seconds
Time After: 0.03708 seconds
End call of global.php: 0.038692951202393
Time Before: 0.04072 seconds
Time After: 0.04088 seconds
Time Before: 0.04337 seconds
Time After: 0.04484 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=127348'
Time Before: 0.06363 seconds
Time After: 0.06390 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
Page generated in 0.062422037124634 seconds with 9 queries, spending 0.0078573226928711 doing MySQL queries and 0.054564714431763 doing PHP things.
