Time Before: 0.02446 seconds
Time After: 0.03835 seconds
Time Taken: 0.01389 seconds
Time Before: 0.03846 seconds
Time After: 0.03894 seconds
Time Before: 0.03919 seconds
Time After: 0.03938 seconds
Time Before: 0.04005 seconds
Time After: 0.04240 seconds
Time Taken: 0.00235 seconds
Time Before: 0.03943 seconds
Time After: 0.04616 seconds
Time Taken: 0.00673 seconds
Time Before: 0.05926 seconds
Time After: 0.05970 seconds
Time Before: 0.06212 seconds
Time After: 0.06383 seconds
Time Taken: 0.00171 seconds
Time Before: 0.05855 seconds
Time After: 0.06409 seconds
Time Taken: 0.00554 seconds
Time Before: 0.10059 seconds
Time After: 0.10078 seconds
Time Before: 0.12121 seconds
Time After: 0.12250 seconds
End call of global.php: 0.12483096122742
Time Before: 0.13565 seconds
Time After: 0.13584 seconds
Time Before: 0.13876 seconds
Time After: 0.14025 seconds
SET lastactivity = 1780671573, location = '/forums/private.php?do=newpm&explain=1&u=127356'
Time Before: 0.16382 seconds
Time After: 0.16410 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.16234683990479 seconds with 9 queries, spending 0.0086121559143066 doing MySQL queries and 0.15373468399048 doing PHP things.
