Time Before: 0.00535 seconds
Time After: 0.00726 seconds
Time Taken: 0.00191 seconds
Time Before: 0.00737 seconds
Time After: 0.00778 seconds
Time Before: 0.00800 seconds
Time After: 0.00816 seconds
Time Before: 0.00882 seconds
Time After: 0.01135 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00821 seconds
Time After: 0.01572 seconds
Time Taken: 0.00750 seconds
Time Before: 0.01994 seconds
Time After: 0.02037 seconds
Time Before: 0.02297 seconds
Time After: 0.02424 seconds
Time Before: 0.01915 seconds
Time After: 0.02449 seconds
Time Taken: 0.00534 seconds
Time Before: 0.03613 seconds
Time After: 0.03624 seconds
Time Before: 0.04203 seconds
Time After: 0.04333 seconds
End call of global.php: 0.045736789703369
Time Before: 0.05117 seconds
Time After: 0.05133 seconds
Time Before: 0.05473 seconds
Time After: 0.05639 seconds
Time Taken: 0.00165 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=127368', badlocation = 1
Time Before: 0.07368 seconds
Time After: 0.07415 seconds
Page generated in 0.072439908981323 seconds with 9 queries, spending 0.0084896087646484 doing MySQL queries and 0.063950300216675 doing PHP things.
