Time Before: 0.01060 seconds
Time After: 0.01924 seconds
Time Taken: 0.00864 seconds
Time Before: 0.01934 seconds
Time After: 0.02059 seconds
Time Before: 0.02083 seconds
Time After: 0.02097 seconds
Time Before: 0.02189 seconds
Time After: 0.02436 seconds
Time Taken: 0.00248 seconds
Time Before: 0.02104 seconds
Time After: 0.02843 seconds
Time Taken: 0.00739 seconds
Time Before: 0.03566 seconds
Time After: 0.03614 seconds
Time Before: 0.03958 seconds
Time After: 0.04083 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03462 seconds
Time After: 0.04112 seconds
Time Taken: 0.00650 seconds
Memory After: 2,261.820 KB
Time Before: 0.05671 seconds
Time After: 0.05686 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07163 seconds
Time After: 0.07291 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.08240 seconds
Time After: 0.08257 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08589 seconds
Time After: 0.08733 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789085543, location = '/forums/private.php?do=newpm&explain=1&u=127377' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.10699 seconds
Time After: 0.10728 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
