Time Before: 0.00146 seconds
Time After: 0.00197 seconds
Time Before: 0.00204 seconds
Time After: 0.00244 seconds
Time Before: 0.00273 seconds
Time After: 0.00289 seconds
Time Before: 0.00375 seconds
Time After: 0.00584 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00297 seconds
Time After: 0.01118 seconds
Time Taken: 0.00821 seconds
Time Before: 0.01307 seconds
Time After: 0.01341 seconds
Time Before: 0.01590 seconds
Time After: 0.01716 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01254 seconds
Time After: 0.01742 seconds
Time Taken: 0.00488 seconds
Memory After: 2,261.703 KB
Time Before: 0.02435 seconds
Time After: 0.02461 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02703 seconds
Time After: 0.02853 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03218 seconds
Time After: 0.03233 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03495 seconds
Time After: 0.03640 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127411', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04947 seconds
Time After: 0.04987 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
