Time Before: 0.01231 seconds
Time After: 0.01526 seconds
Time Taken: 0.00295 seconds
Time Before: 0.01537 seconds
Time After: 0.01578 seconds
Time Before: 0.01602 seconds
Time After: 0.01615 seconds
Time Before: 0.01696 seconds
Time After: 0.01924 seconds
Time Taken: 0.00228 seconds
Time Before: 0.01622 seconds
Time After: 0.02341 seconds
Time Taken: 0.00719 seconds
Time Before: 0.02745 seconds
Time After: 0.02785 seconds
Time Before: 0.03093 seconds
Time After: 0.03215 seconds
Time Before: 0.02677 seconds
Time After: 0.03237 seconds
Time Taken: 0.00560 seconds
Time Before: 0.05247 seconds
Time After: 0.05260 seconds
Time Before: 0.06243 seconds
Time After: 0.06369 seconds
End call of global.php: 0.066423892974854
Time Before: 0.07052 seconds
Time After: 0.07067 seconds
Time Before: 0.07287 seconds
Time After: 0.07438 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=127477'
Time Before: 0.09025 seconds
Time After: 0.09062 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.089102029800415 seconds with 9 queries, spending 0.0078721046447754 doing MySQL queries and 0.08122992515564 doing PHP things.
