Time Before: 0.00857 seconds
Time After: 0.01122 seconds
Time Taken: 0.00265 seconds
Time Before: 0.01132 seconds
Time After: 0.01183 seconds
Time Before: 0.01205 seconds
Time After: 0.01219 seconds
Time Before: 0.01290 seconds
Time After: 0.01536 seconds
Time Taken: 0.00246 seconds
Time Before: 0.01224 seconds
Time After: 0.01991 seconds
Time Taken: 0.00768 seconds
Time Before: 0.02595 seconds
Time After: 0.02641 seconds
Time Before: 0.02796 seconds
Time After: 0.02919 seconds
Time Before: 0.02526 seconds
Time After: 0.02941 seconds
Time Taken: 0.00415 seconds
Time Before: 0.04845 seconds
Time After: 0.04861 seconds
Time Before: 0.05721 seconds
Time After: 0.05850 seconds
End call of global.php: 0.060783863067627
Time Before: 0.06525 seconds
Time After: 0.06541 seconds
Time Before: 0.06790 seconds
Time After: 0.06935 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=127496'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.08697 seconds
Time After: 0.08731 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.085735082626343 seconds with 9 queries, spending 0.0081815719604492 doing MySQL queries and 0.077553510665894 doing PHP things.
