Time Before: 0.00150 seconds
Time After: 0.00214 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00221 seconds
Time After: 0.00284 seconds
Time Before: 0.00465 seconds
Time After: 0.00535 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00619 seconds
Time After: 0.00829 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00541 seconds
Time After: 0.01171 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01357 seconds
Time After: 0.01401 seconds
Time Before: 0.01548 seconds
Time After: 0.01675 seconds
Time Before: 0.01297 seconds
Time After: 0.01699 seconds
Time Taken: 0.00402 seconds
Time Before: 0.02371 seconds
Time After: 0.02389 seconds
Time Before: 0.02627 seconds
Time After: 0.02756 seconds
End call of global.php: 0.029252052307129
Time Before: 0.03044 seconds
Time After: 0.03066 seconds
Time Before: 0.03266 seconds
Time After: 0.03418 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=127565'
Time Before: 0.04739 seconds
Time After: 0.04847 seconds
Time Taken: 0.00108 seconds
Page generated in 0.046472072601318 seconds with 9 queries, spending 0.0094423294067383 doing MySQL queries and 0.03702974319458 doing PHP things.
