Time Before: 0.00191 seconds
Time After: 0.00240 seconds
Time Before: 0.00247 seconds
Time After: 0.00280 seconds
Time Before: 0.00301 seconds
Time After: 0.00320 seconds
Time Before: 0.00389 seconds
Time After: 0.00648 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00325 seconds
Time After: 0.01089 seconds
Time Taken: 0.00764 seconds
Time Before: 0.01294 seconds
Time After: 0.01338 seconds
Time Before: 0.01601 seconds
Time After: 0.01730 seconds
Time Before: 0.01226 seconds
Time After: 0.01753 seconds
Time Taken: 0.00527 seconds
Time Before: 0.02451 seconds
Time After: 0.02464 seconds
Time Before: 0.02647 seconds
Time After: 0.02776 seconds
End call of global.php: 0.030394077301025
Time Before: 0.03185 seconds
Time After: 0.03201 seconds
Time Before: 0.03514 seconds
Time After: 0.03689 seconds
Time Taken: 0.00174 seconds
SET lastactivity = 1788907334, location = '/forums/private.php?do=newpm&explain=1&u=127574', badlocation = 1
Time Before: 0.05356 seconds
Time After: 0.05380 seconds
Page generated in 0.052642107009888 seconds with 9 queries, spending 0.0083999633789062 doing MySQL queries and 0.044242143630981 doing PHP things.
