Time Before: 0.02156 seconds
Time After: 0.02904 seconds
Time Taken: 0.00748 seconds
Time Before: 0.02912 seconds
Time After: 0.02953 seconds
Time Before: 0.02978 seconds
Time After: 0.02989 seconds
Time Before: 0.03066 seconds
Time After: 0.03316 seconds
Time Taken: 0.00250 seconds
Time Before: 0.02995 seconds
Time After: 0.03743 seconds
Time Before: 0.04655 seconds
Time After: 0.04693 seconds
Time Before: 0.04932 seconds
Time After: 0.05054 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04585 seconds
Time After: 0.05073 seconds
Time Taken: 0.00487 seconds
Memory After: 2,261.820 KB
Time Before: 0.08399 seconds
Time After: 0.08441 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.11225 seconds
Time After: 0.11353 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.11591815948486
Time Before: 0.12757 seconds
Time After: 0.12773 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13031 seconds
Time After: 0.13184 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788887233, location = '/forums/private.php?do=newpm&explain=1&u=127588'
Time Before: 0.15054 seconds
Time After: 0.15085 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.14956092834473 seconds with 9 queries, spending 0.0083293914794922 doing MySQL queries and 0.14123153686523 doing PHP things.
