Time Before: 0.00703 seconds
Time After: 0.01025 seconds
Time Taken: 0.00322 seconds
Time Before: 0.01035 seconds
Time After: 0.01082 seconds
Time Before: 0.01111 seconds
Time After: 0.01131 seconds
Time Before: 0.01207 seconds
Time After: 0.01445 seconds
Time Taken: 0.00238 seconds
Time Before: 0.01138 seconds
Time After: 0.01878 seconds
Time Taken: 0.00740 seconds
Time Before: 0.02305 seconds
Time After: 0.02348 seconds
Time Before: 0.02498 seconds
Time After: 0.02621 seconds
Time Before: 0.02230 seconds
Time After: 0.02643 seconds
Time Taken: 0.00413 seconds
Time Before: 0.04037 seconds
Time After: 0.04051 seconds
Time Before: 0.04567 seconds
Time After: 0.04702 seconds
Time Taken: 0.00135 seconds
Time Before: 0.05255 seconds
Time After: 0.05273 seconds
Time Before: 0.05559 seconds
Time After: 0.05704 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127606', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.07585 seconds
Time After: 0.07613 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
