Time Before: 0.00188 seconds
Time After: 0.00351 seconds
Time Taken: 0.00162 seconds
Time Before: 0.00362 seconds
Time After: 0.00396 seconds
Time Before: 0.00427 seconds
Time After: 0.00440 seconds
Time Before: 0.00515 seconds
Time After: 0.00767 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00448 seconds
Time After: 0.01150 seconds
Time Taken: 0.00702 seconds
Time Before: 0.01352 seconds
Time After: 0.01386 seconds
Time Before: 0.01519 seconds
Time After: 0.01644 seconds
Time Before: 0.01287 seconds
Time After: 0.01664 seconds
Time Taken: 0.00377 seconds
Time Before: 0.02235 seconds
Time After: 0.02250 seconds
Time Before: 0.02449 seconds
Time After: 0.02570 seconds
End call of global.php: 0.027355909347534
Time Before: 0.02874 seconds
Time After: 0.02889 seconds
Time Before: 0.03091 seconds
Time After: 0.03240 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=127732', badlocation = 1
Time Before: 0.04875 seconds
Time After: 0.04904 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.047415971755981 seconds with 9 queries, spending 0.0079045295715332 doing MySQL queries and 0.039511442184448 doing PHP things.
