Time Before: 0.00173 seconds
Time After: 0.00243 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00250 seconds
Time After: 0.00284 seconds
Time Before: 0.00307 seconds
Time After: 0.00318 seconds
Time Before: 0.00384 seconds
Time After: 0.00633 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00322 seconds
Time After: 0.00976 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01153 seconds
Time After: 0.01222 seconds
Time Taken: 0.00069 seconds
Time Before: 0.01381 seconds
Time After: 0.01504 seconds
Time Before: 0.01100 seconds
Time After: 0.01521 seconds
Time Taken: 0.00421 seconds
Time Before: 0.02204 seconds
Time After: 0.02218 seconds
Time Before: 0.02475 seconds
Time After: 0.02598 seconds
Time Before: 0.02905 seconds
Time After: 0.02919 seconds
Time Before: 0.03124 seconds
Time After: 0.03269 seconds
UPDATE session SET lastactivity = 1783046010, location = '/forums/private.php?do=newpm&explain=1&u=127747' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.05078 seconds
Time After: 0.05108 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
