Time Before: 0.01756 seconds
Time After: 0.02209 seconds
Time Taken: 0.00453 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02222 seconds
Time After: 0.02273 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02300 seconds
Time After: 0.02312 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02406 seconds
Time After: 0.02683 seconds
Time Taken: 0.00277 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02321 seconds
Time After: 0.03092 seconds
Time Taken: 0.00771 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03697 seconds
Time After: 0.03743 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03885 seconds
Time After: 0.04012 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.03610 seconds
Time After: 0.04035 seconds
Time Taken: 0.00425 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.07305 seconds
Time After: 0.07318 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.12108 seconds
Time After: 0.12229 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.14801 seconds
Time After: 0.14815 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.15309 seconds
Time After: 0.15454 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127798', badlocation = 1 WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.17917 seconds
Time After: 0.17943 seconds
Memory Before: 5,998.641 KB
Memory After: 5,998.859 KB
