Time Before: 0.00199 seconds
Time After: 0.00254 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00264 seconds
Time After: 0.00322 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00348 seconds
Time After: 0.00362 seconds
Time Before: 0.00432 seconds
Time After: 0.00692 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00367 seconds
Time After: 0.01036 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01213 seconds
Time After: 0.01258 seconds
Time Before: 0.01507 seconds
Time After: 0.01631 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01153 seconds
Time After: 0.01648 seconds
Time Taken: 0.00495 seconds
Memory After: 2,261.836 KB
Time Before: 0.02132 seconds
Time After: 0.02145 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02330 seconds
Time After: 0.02454 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.026155948638916
Time Before: 0.02724 seconds
Time After: 0.02738 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.02945 seconds
Time After: 0.03120 seconds
Time Taken: 0.00175 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788882398, location = '/forums/private.php?do=newpm&explain=1&u=12781'
Time Before: 0.04360 seconds
Time After: 0.04382 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.042703866958618 seconds with 9 queries, spending 0.0084824562072754 doing MySQL queries and 0.034221410751343 doing PHP things.
