Time Before: 0.03146 seconds
Time After: 0.04099 seconds
Time Taken: 0.00953 seconds
Time Before: 0.04110 seconds
Time After: 0.04180 seconds
Time Taken: 0.00071 seconds
Time Before: 0.04220 seconds
Time After: 0.04233 seconds
Time Before: 0.04321 seconds
Time After: 0.04752 seconds
Time Taken: 0.00432 seconds
Time Before: 0.04241 seconds
Time After: 0.05173 seconds
Time Taken: 0.00932 seconds
Time Before: 0.06023 seconds
Time After: 0.06040 seconds
Time Before: 0.06280 seconds
Time After: 0.06396 seconds
Time Taken: 0.00116 seconds
Time Before: 0.05959 seconds
Time After: 0.06419 seconds
Time Taken: 0.00460 seconds
Time Before: 0.10208 seconds
Time After: 0.10221 seconds
Time Before: 0.23213 seconds
Time After: 0.23336 seconds
Time Before: 0.24181 seconds
Time After: 0.24194 seconds
Time Before: 0.24423 seconds
Time After: 0.24564 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127851', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.26466 seconds
Time After: 0.26489 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
