Time Before: 0.00697 seconds
Time After: 0.00909 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00918 seconds
Time After: 0.00968 seconds
Time Before: 0.01000 seconds
Time After: 0.01027 seconds
Time Before: 0.01113 seconds
Time After: 0.01377 seconds
Time Taken: 0.00264 seconds
Time Before: 0.01033 seconds
Time After: 0.01772 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02287 seconds
Time After: 0.02328 seconds
Time Before: 0.02562 seconds
Time After: 0.02691 seconds
Time Before: 0.02218 seconds
Time After: 0.02713 seconds
Time Taken: 0.00495 seconds
Time Before: 0.04369 seconds
Time After: 0.04382 seconds
Time Before: 0.05043 seconds
Time After: 0.05166 seconds
End call of global.php: 0.053512096405029
Time Before: 0.05812 seconds
Time After: 0.05829 seconds
Time Before: 0.06067 seconds
Time After: 0.06215 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=127900', badlocation = 1
Time Before: 0.07965 seconds
Time After: 0.07997 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.078567981719971 seconds with 9 queries, spending 0.0084588527679443 doing MySQL queries and 0.070109128952026 doing PHP things.
