Time Before: 0.01179 seconds
Time After: 0.01610 seconds
Time Taken: 0.00430 seconds
Time Before: 0.01617 seconds
Time After: 0.01660 seconds
Time Before: 0.01681 seconds
Time After: 0.01695 seconds
Time Before: 0.01771 seconds
Time After: 0.02041 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01700 seconds
Time After: 0.02456 seconds
Time Taken: 0.00756 seconds
Time Before: 0.03011 seconds
Time After: 0.03054 seconds
Time Before: 0.03378 seconds
Time After: 0.03503 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02939 seconds
Time After: 0.03530 seconds
Time Taken: 0.00591 seconds
Memory After: 2,261.703 KB
Time Before: 0.05591 seconds
Time After: 0.05607 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06865 seconds
Time After: 0.06990 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.07193398475647
Time Before: 0.07613 seconds
Time After: 0.07632 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07933 seconds
Time After: 0.08077 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=127951'
Time Before: 0.09519 seconds
Time After: 0.09548 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.094269037246704 seconds with 9 queries, spending 0.0082728862762451 doing MySQL queries and 0.085996150970459 doing PHP things.
