Time Before: 0.01942 seconds
Time After: 0.02417 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02426 seconds
Time After: 0.02471 seconds
Time Before: 0.02497 seconds
Time After: 0.02512 seconds
Time Before: 0.02601 seconds
Time After: 0.02856 seconds
Time Taken: 0.00256 seconds
Time Before: 0.02519 seconds
Time After: 0.03323 seconds
Time Taken: 0.00804 seconds
Time Before: 0.03748 seconds
Time After: 0.03790 seconds
Time Before: 0.04064 seconds
Time After: 0.04189 seconds
Time Before: 0.03653 seconds
Time After: 0.04214 seconds
Time Taken: 0.00560 seconds
Time Before: 0.06896 seconds
Time After: 0.06912 seconds
Time Before: 0.08087 seconds
Time After: 0.08212 seconds
Time Before: 0.09111 seconds
Time After: 0.09131 seconds
Time Before: 0.09464 seconds
Time After: 0.09615 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=127954' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.11361 seconds
Time After: 0.21926 seconds
Time Taken: 0.10565 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
