Time Before: 0.00138 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00237 seconds
Time Before: 0.00259 seconds
Time After: 0.00270 seconds
Time Before: 0.00343 seconds
Time After: 0.00653 seconds
Time Taken: 0.00311 seconds
Time Before: 0.00275 seconds
Time After: 0.00997 seconds
Time Taken: 0.00721 seconds
Time Before: 0.01179 seconds
Time After: 0.01220 seconds
Time Before: 0.01538 seconds
Time After: 0.01657 seconds
Time Before: 0.01116 seconds
Time After: 0.01675 seconds
Time Taken: 0.00559 seconds
Time Before: 0.02273 seconds
Time After: 0.02288 seconds
Time Before: 0.02580 seconds
Time After: 0.02708 seconds
End call of global.php: 0.030068159103394
Time Before: 0.03208 seconds
Time After: 0.03225 seconds
Time Before: 0.03593 seconds
Time After: 0.03741 seconds
SET lastactivity = 1776492976, location = '/forums/private.php?do=newpm&explain=1&u=127978', badlocation = 1
Time Before: 0.05016 seconds
Time After: 0.05057 seconds
Page generated in 0.04924201965332 seconds with 9 queries, spending 0.008709192276001 doing MySQL queries and 0.040532827377319 doing PHP things.
