Time Before: 0.00161 seconds
Time After: 0.00213 seconds
Time Before: 0.00220 seconds
Time After: 0.00259 seconds
Time Before: 0.00278 seconds
Time After: 0.00292 seconds
Time Before: 0.00364 seconds
Time After: 0.00601 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00296 seconds
Time After: 0.00934 seconds
Time Taken: 0.00637 seconds
Time Before: 0.01110 seconds
Time After: 0.01155 seconds
Time Before: 0.01473 seconds
Time After: 0.01592 seconds
Time Before: 0.01052 seconds
Time After: 0.01612 seconds
Time Taken: 0.00560 seconds
Time Before: 0.02129 seconds
Time After: 0.02148 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:5:\"4.68,\";s:9:\"lastcheck\";i:1783087516;}', 1)Time Before: 0.02817 seconds
Time After: 0.02885 seconds
Time Taken: 0.00068 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.03156 seconds
Time After: 0.03278 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.03697 seconds
Time After: 0.03718 seconds
Memory Before: 4,164.359 KB
Memory After: 4,164.789 KB
Time Before: 0.03946 seconds
Time After: 0.04089 seconds
Memory Before: 4,446.148 KB
Memory After: 4,447.836 KB
UPDATE session SET lastactivity = 1783087516, location = '/forums/private.php?do=newpm&explain=1&u=127991', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05393 seconds
Time After: 0.05422 seconds
Memory Before: 4,920.078 KB
Memory After: 4,920.289 KB
