Time Before: 0.00166 seconds
Time After: 0.00237 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00248 seconds
Time After: 0.00289 seconds
Time Before: 0.00307 seconds
Time After: 0.00321 seconds
Time Before: 0.00395 seconds
Time After: 0.00626 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00326 seconds
Time After: 0.00979 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01230 seconds
Time After: 0.01275 seconds
Time Before: 0.01423 seconds
Time After: 0.01542 seconds
Time Before: 0.01153 seconds
Time After: 0.01560 seconds
Time Taken: 0.00407 seconds
Time Before: 0.02107 seconds
Time After: 0.02120 seconds
Time Before: 0.02352 seconds
Time After: 0.02479 seconds
End call of global.php: 0.026750087738037
Time Before: 0.02792 seconds
Time After: 0.02807 seconds
Time Before: 0.03030 seconds
Time After: 0.03172 seconds
SET lastactivity = 1789115869, location = '/forums/private.php?do=newpm&explain=1&u=127994'
Time Before: 0.04417 seconds
Time After: 0.04507 seconds
Time Taken: 0.00090 seconds
Page generated in 0.043264150619507 seconds with 9 queries, spending 0.0083703994750977 doing MySQL queries and 0.034893751144409 doing PHP things.
